-   -   Gearing for a racebomb with ue diffs (https://www.rc-monster.com/forum/showthread.php?t=2899)
rchippie 04.19.2006 01:54 AM
I getting me CF racebomb going again & need gearing advice. I will be useing a 7XL on 14 cells with ue diffs & robinson gears on a kippster slipper for know, untill strobe's are avalible again. I have both the large & small kippster slippers. I have all the robinson gears & i have 14 16 & 18 tooth pinions.
Sneeck 04.19.2006 02:58 AM
I'd say around 72/ 16 and go from there.
coolhandcountry 04.19.2006 07:59 AM
I would say for the 14 cells go with like a 18 66. It would depend on the size of the tires to.
Sylvester 04.19.2006 09:40 AM
The slippers are back, rchippie:)
nitrostarter 04.19.2006 05:49 PM
I run 16/51 with my Torpedo, 7xl 14-16cells. with UE diffs and 40series RoadRage and CF's. Good temps all around.
rchippie 04.19.2006 07:20 PM
Since the strobe slippers are avalible again from mike i decided to use mod 1 gears. I got a recomendation of a 16-51 pinion & spur combo with ue diffs. Would you BL experts agree with this recomendation. I would like to buy the slipper tonight from mike so your quick response would be appreciated. Please give a recomendation for a 9L & 7XL. Thank's
coolhandcountry 04.19.2006 07:24 PM
16 51 gearing with ue diffs is like stock gearing the emaxx comes with. I would run this and not worry on 14 cells. Unless you got some big tires or something hippie. This is for 7xl. 9L I would try a 14 51 gearing and would question 14 cells on it.
