Muggy owners??
Hey guys can you give me a hand with my set-up? I'm not sure if I need to use thicker oil in the front or center diff or ??
When I gun it from a dead stop this happens: 1. The front end comes up about 6-7 inches. 2. The front wheels balloon like a top fuel dragster. 3. The front comes down and the wheels squeal like a plane landing. Then it takes off. I've watched a few videos and most Muggys either pop a wheelie or just take off. At this rate my front wheels should last about 2 more runs. My current set-up: CC 1518 MMM 30C 4s Lipo (soon 5s) 14T pinion / stock spur stock wheels |
Thicker oil in the center
What's your current diff setup?
I bought the truck nitro RTR from someone else so I'm not sure what he had for oil.
Can you recommend some starting weights? I think I have 1000/3000/5000 on my shelf. Maybe 7000 too. Thanks! |
30-50k in center for a basher
Wow. Ok thanks.
I think I have 10-30-5 (F-C-R) in mine, works well.
I run 10k-100k-10k in my Muggy with gorilla-taped badlands. No problems.
Guess I'll be buying some diff oil! I'm used to my Kyosho buggy but this beast is a little different.
100K:surprised: I would think that's as good as a no diff at all. Interesting. Thanks a lot guys. I look forward to the difference. |
It also depends if you are running brushless or not. In my brushless I run 30-100-25. in my nitro I run 25-50-20. My brushless has 17mm wheels though.
| All times are GMT -4. The time now is 07:18 AM. |
