-   -   Need to countersink holes in CF, which bit do I need? (https://www.rc-monster.com/forum/showthread.php?t=29004)
simplechamp 01.09.2011 05:27 PM
I need to drill 4 (or possibly 8) holes in the bottom of a CF chassis for mounting lipo trays. The screws are M3, and I already have a 3mm pure carbide bit for drilling the holes, but I also need a bit to countersink the holes.
Can anyone suggest the bit I should use? I would like to find something cheap, even if that means tossing it out after I'm done. I know the CF dulls tools fast.
PBO 01.09.2011 05:33 PM
Just a regular CSK bit will work fine for 4 holes
http://t3.gstatic.com/images?q=tbn:A...lTvbtuR2G45QLQ
simplechamp 01.09.2011 05:43 PM
Do I need a certain angle or anything? Or are metric flatheads a standard angle on the head?
EDIT: Wikipedia says "Countersink cutters are manufactured with six common angles, which are 60°, 82°, 90°, 100°, 110°, or 120°, with the two most common of those being 82° and 90°. Countersunk-head screws that follow the Unified Thread Standard very often have an 82° angle, and screws that follow the ISO standard very often have a 90° angle."
So which do I need?
PBO 01.09.2011 06:45 PM
So which do I need?
Well, do you now the CSK angle of the screw head? that would be the answer
I wouldn't worry too much about pressure angles unless the tensile load is extreme. If you want to be certain, bed the screws in with epoxy - this will allow mirrored pressure angles
mjderstine 01.09.2011 07:23 PM
the most common at 82. so unless you got goofy screws you should be fine!
simplechamp 01.09.2011 07:51 PM
Just using standard M3x0.5 flatheads. I didn't know if they are Unified Thread Standard or ISO like the Wikipedia entry mentioned. Just did a bit more searching and looks like they are ISO so I'm going to use a 90° countersink
brushlessboy16 01.09.2011 07:51 PM
Metrics use 90 degree IIRC
pb4ugo 01.09.2011 10:00 PM
BB16 is right--metrics are 90 and standards are 82. I've had difficulty finding 90 deg countersinks locally, so the best setup I've found is a 90 deg carbide router bit. If only four, you could get away with HSS, but the carbide isn't too much more in router bits.
brushlessboy16 01.09.2011 10:52 PM
Mcmaster carr
P/n 3013A43
mjderstine 01.10.2011 11:42 PM
oh, my bad, i have been using 82 on metrics for a while now without an issue... just torque em down :) :)
