Losi Ten-T Motor Mount
I am planning a Losi 810 conversion.
Does anyone know how to order the Losi Ten-T motor mount individually? Does it require the custom 32P spur gear? |
The Ten T mount isn't just a mount like alot of the other conversions. It doesn't just replace one of the center diff supports. There is a botton plate, top plate, and the actual motor mount. The stock spur is a strange pitch so the 32P spur is needed, otherwise finding pinions is a problem. You might try PMing Mike to see if he can supply a conversion without the battery tray.
-JB |
Go with the conversion from RCM. There may be others out their complaining about Mikes mount design, but to be honest I think it was user error, I have a freaking Castle 22oo bolted up to mine and have never had a problem. Mike has also got the better battery tray, I have heard that the other one, which looks like a blatant copy, has hard times fitting larger cells. Mike's fits everything I have. Mike is pretty cool when it comes to talking things out over the phone as well.
Thanks, I'll go with the RCM conversion kit.
I just need to figure out what pinion to use with a T8 2050 |
http://scriptasylum.com/rc_speed/index.html
Your best bet. |
| All times are GMT -4. The time now is 05:15 AM. |
