Question about 2200KV on Ext. Savage for Castle Staff
This is my current setup, I test it last night in front of my home, and I notice that sometimes at start the truck move pretty slow, no matter I press the full throttle. But when is moving normally if I press the throttle a little more It does the Satan wheelie. I don't have enough amps on the batts for this setup? I solder two 35V big capacitors a time ago on the MMM. This is my first time with lipos.
The truck is two year old, the wheelbase is 17". I only change the bearings once. Differential Ratio: 3.2222222222222223 Transmission Ratio: 2.215277777777778 Other Ratio: 1 Spur Tooth Count: 44 Pinion Tooth Count: 18 Total Voltage: 22.20 6s Lipo 40-50C (Cheap ones) 5000mAh They are new. Motor KV: 2200 Tire Diameter (inches): 6.69 Tire Ballooning (inches): 0 Motor Current Draw: 0 Motor Coil Resistance: 0.006 Spur/Pinion Ratio: 2.44 : 1 Total Ratio: 17.44873 : 1 Tire Circumference (inches): 21.02 inches (533.84 mm) Rollout: 1.20:1 Total Motor Speed: 48840 RPM Vehicle Speed: 55.71 mph (89.49 km/h) Effective KV Value: 2200 KT constant: 0.61 oz-in/A I'm going to test tonight with the 52T spur = 47.14 mph. To see what happens. A pic of the truck http://img254.imageshack.us/img254/654/sspx0350.jpg |
6S 40/50C, but what is the mah capacity? Example, 3000mah 5000mah...
If it pulls wheelies I would say you have sufficient power, maybe it's a setting? What is the "start-up" power set to? |
Yah, test it with a little more start power :-)
P.s. I noticed you had "for Castle Staff" in your title, I'm not castle staff, but I'll help if I can :-) |
Thanks DrKnow65 |
Maybe a bad firmware, try the 1.24 version for see ?
A friend have a Kyosho GT2 with a 2200KV system (72MPH single speed) and start behave weird after a update so we roll back it to 1.21 and work great. |
Well 1.30 dont work for me, 1.21 runs great. So I should apply something that I apply at work "If something work great dont upgrade it, unless is Microsoft software or the Antivirus" |
I didn't like 1.30 either. It starts moving, then "kicks in". Went down to the last non-beta release.
I dunno, kind of torn on the upgrading microsoft part.
I do upgrade my windows 7 professional 64bit pc's here at home, but I have one that I kept XP on, and NEVER let it do ONE update. It lasted years and years and never had a crash (Dell 8300) and is now running W7 32bit happily... |
Vista work great after the updates but still pretty slow. (Never install on my labs, thank god) Windows 7 64/32 version are pretty great. |
7 x64 pro has been as sweet as I had hoped every other windows would be.
P.s. sorry for the hijack |
| All times are GMT -4. The time now is 08:03 AM. |
