shock set-up ideas
ok, getting closer to completion..... FLM/GPM stampede
but before i start building the shocks, what should i use....... here's what i got at hand without running to the store.... GPM shock w/ rezzies, feel like standard weight springs, 2 hole pistons..... 1 / 2 / 3 hole pistons to choose from (stock Traxxas, may need slight sanding to fit), (instead of messing those up, might just stick with the 2 hole pistons that came with GPM shocks) and 30 / 45 / 60 wt. Trinity shock oils suggestions on best set-up for front and rear, keep 'em the same, or different since i got the option? mostly bashing, maybe some racing.... |
depending on the weight i would say 30 or 40ish.
| All times are GMT -4. The time now is 11:52 PM. |
