-   -   5.5mm connectors (https://www.rc-monster.com/forum/showthread.php?t=2922)
neweuser 04.21.2006 10:34 PM
5.5mm connectors
This is a dumb question, as i'm sure i have asked many by now. But the male connectors, what is the best way to attach them to the wire to the controller?:007:
squeeforever 04.21.2006 11:14 PM
solder
neweuser 04.22.2006 03:25 AM
just dump solder in the holes on the side of the connector? they a goldish, will the solder stick ok? if i use a little flux? makes sense, can you confirm??? thanks again mills man!!!!
Serum 04.22.2006 04:03 AM
strip the wire a bit too long, stuff all the wire in the 5.5 and let the solder do the rest of the job..
neweuser 04.22.2006 09:15 AM
Thanks! getting closer!!!!
coolhandcountry 04.22.2006 12:37 PM
You forgot to put flux in hole first rene. The solder don't like to stick with out the flux.
Serum 04.22.2006 02:22 PM
If you've got the solder with resin in it, there really is no need for flux, the plugs are clean enough.
BrianG 04.22.2006 04:07 PM
And you gotta get those plugs and wires hot so the solder bonds to the metal. Even if the solder itself melts, it might not bond to the connector/wire unless both are hot enough. Cold solder joint=bad connection=hot connector under high amperage and a little less voltage at your motor.
coolhandcountry 04.22.2006 04:35 PM
I have alot better luck with a little flux. I would rather use and stick than not and not stick. Easier to do it once.
neweuser 04.24.2006 09:09 AM
Got them on perfect, used a little flux. WEnt very well and very clean! both were definatley hot enough. Much easier than deans i might add!!!!!
coolhandcountry 04.24.2006 03:35 PM
Sweet. That means you that much closer to a test drive.
neweuser 04.24.2006 04:39 PM
I'm thinking rx battery pack tonight and see if can't get a run in....did you check out the pics? I got them to work FINALLY!
