Best conversion for 8ight-T?
HI
I should give an advice to my friend to convert his 8ight-T to brushless. What is the best conversion for 8ight-T right now? My choice was rc-monster conversion for my MBX6-T but I couldn't find a conversion kit for 8ight-t on rc-monster store:no: |
i went with the rc-monster motor mount and battery tray also looks great and the fit and finish is amazing
scott |
Has the battery tray a esc mounting plate? and what are the inner dimensions? I'm considering the e-losi conversions battery tray too but don't know which is better (lighter, has more room for battery and mount lower)
Most likely the losi battery tray is made to only hold roar approved hardpacks, either a single 4s hardcase or two 2s hardcases. The RC-Monster tray is a far better choice and you can get one with a esc mounting tray
mine has the esc mounting plate not sure to the dimensions as i am not home i will check when i get home
scott |
Battery tray is on this page of the store, use the drop down menu to select it. Internal dimensions are 168mm x 55mm and Mike says it is closer to the centerline and lower than the Losi Tray. Weight difference is probably insignificant.
http://www.rc-monster.com/proddetail...MFPbatterytray For pics of the tray installed and the esc shelf, ignore the old style motor mount http://www.rc-monster.com/forum/showthread.php?t=26801 Motor mount. http://www.rc-monster.com/proddetail...d=RCMLosiMount |
| All times are GMT -4. The time now is 01:22 PM. |
