Savage Flux For Sale
This is one of my pride and joys. I've invested a ton of time and money to make this indestructable truck even better. You will not be able to keep a grin off your face when you pull the throttle! ;)
Here's all the parts and upgrades it has: Electronics/Batteries: -MMM ESC with Flux Tork 2200kv motor (sealed front endbell with screws, rear with electrical tape) Zip tied in place so the motor dosn't move forward on bad landings. Both in great shape, and the motor has never been over 125 degrees. The MMM fan is broken, but works great otherwise. -Battery Box Mods: Opened up rear went, flipped around, and some extra foam -Velcro around battery boxes to keep them from popping open. Suspension: -HPI Swaybar Kit. Really helps with cornering and keeping the truck on its feet -Losi 45wt Shock Oil -White Hellfire Springs -Black Bas Horsie Shock Socks -Tube mod with Extra Spacer -RPM A-Arms (Not installed) Steering: -Ball Bearings on the Steering Posts -Shaved hub/axle carrier Mods for a MUCH better steering radius! -HPI SF-50 steering servo Drivetrain: -HD Drive Cups (on the Diffs/Bulks) -HD Interior Tranny Gears (All shimmed correctly with some extra diff shims) -Robinson racing Hardened 20T Pinion Gear -Diffs Filled with 50,000wt Ofna Diff oil, and Losi Black Grease on the Orings for a better Seal -Extra interior diff shims to eliminate play -Slipper Tightened All the Way down Chassis: -TCS 5mm Standard Length Red Chassis -Tony's Screws Hex Screw kit used throughout (very nice kit, would recomend it) -Threadlock used on all metal-on-metal screws -Heavy duty bumper screws front and rear -Integy rear aluminum axle carriers to eliminate breaking the rear tierods. Pretty much one of the only good parts integy has ever made! :lol: Bodies: -Stock Flux Body -Proline 2008 Ford F-250 Body -Proline Body (Black) (Not sure what it is?) -HPI 1969 Doge Charger Body Tires: -HPI Mud trencher Tires on HPI Wheels (Not Pictured) In almost new condition. On wheel has it's hex stripped, but i have run it multiple times like this as a rear tire and it works great, just make sure to keep the nut very tight. I will also include another wheel if you want to unglue it and put it on that. -HPI Dirt Bonez Tires on HPI Wheels (Not pictured) Great condition -Ton of extra parts, chassis, shocks, driveshafts, a-arms, etc. Over $100 worth. That's about it. I really love the way this truck handles, has great steering radius. Torque is insane even on 4s lipos, standing backflips are sweet! The suspension is plush enough for small stuff, but can take the big jumps too! This truck is tough as nails. You won't be able to keep the grin off your face once you pull the throttle! PM me with an offer. I'm open to trades, especially for a 1/10th electric buggy, 2wd or 4wd. Maybe a really nice .21 truggy motor and some cash. Also looking for a low kv 1/8 buggy motor, around 1400kv, and lipo batteries. Nice 2s packs, 4s, 5s, 6s. I'll also consider other offers. I can also include 2 Turnigy 30c 2s 5200mah hardcase lipos in great condition And a Hitec 7955TG servo Spektrum SR3000 Receiver I have a bunch of feedback on RCTECH under my username. Please PM me with questions or offers! Thanks http://www.rctech.net/forum/attachme...d-dsc_0026.jpg http://www.rctech.net/forum/attachme...d-dsc_0027.jpg http://www.rctech.net/forum/attachme...d-dsc_0021.jpg http://www.rctech.net/forum/attachme...-motor-esc.jpg http://www.rctech.net/forum/attachme...d-dsc_0022.jpg |
| All times are GMT -4. The time now is 10:57 AM. |
