-   -   Kyosho Blizzard, brushless power (https://www.rc-monster.com/forum/showthread.php?t=29294)
Ola 02.11.2011 01:48 AM
Hi
New here, from Norway..
Been reading this forum for a while, and found alot of great info, so i thought i would join you :yes:
As a side project from my e-revo, i got a Blizzard to play with in the snow..
I mounted a 4300kv + esc from HK, went all in for 3s 4000mah lipo, 27t pinion (17t stock), put inn ball bearings instead of bushings (26pcs i think it was), and 120k wt in the diff for better traction!
I wonder what the scale speed would be :lol:
A short movie of it:
http://www.youtube.com/watch?v=W-3clJNcEzY
What's_nitro? 02.11.2011 02:51 AM
BLIZZARD SPEED RUNS! :lol:
That's cool man. I hope it holds together for you. I had mine fitted with a LMT BasicXL 2800 on 4s lipo.....it was fast. :mdr:
Welcome to RC-Monster! :yipi:
josh9mille 02.11.2011 12:27 PM
that thing hauls azz! So what kind of radio do you use for that? I would immagine it would be a stick radio for airplanes so you can control each track independently?
_paralyzed_ 02.11.2011 12:44 PM
It's actually a single motor with a differential with left and right brakes off one servo that steer a blizzard. Turn left and the left track locks. Turn right and the right track locks. Any radio would work.
brainanator 02.11.2011 12:46 PM
AHAHHAHAHHA man, I busted out laughing when it took off like a rocket!!!!
That is really cool! I like it a lot.
Good stuff, thanks for sharing and welcome to the forums.
Krawlin 02.11.2011 12:51 PM
Actually Kyosho Blizzards use a differential between the tracks with a brake disc on each side. To steer, it uses a single servo that applies the brake on 1 side or the other. You can use a pistol type radio for this, but if one were so inclined, I guess you could use a stick radio for airplane, but really it would be doing the same thing, unless you set it up for dual motors, 1 driving each track.
EDIT: Whoops, Harold posted the same thing while I was typing this up. :oops:
Ola 02.11.2011 01:50 PM
Yup, i use a futaba 3pm pistol :)
Its a real handfull to drive though :lol: You need to be _very_ careful when steering..
The brakes is steel on steel, and even if it got way better after the 120k diff oil, and some modding on the brake linkage, it`s still kinda digital :whistle:
I`m going to mod the brake pads too later, to get less grip on the brake disk..
And i need a tougher body, with alot less details.. I almost made a backflip last time i was out, so the body gets a beating LOL
