Some SCT MMP 2400 Testing
Hello Folks,
Did some more testing on my car today, data is from an Eagletree V4 Logger Car Setup Info Slash 4x4 SCT MMP 2400kv Combo Geared 21/52 (22/54 or 20/50), Slipper Proline Streetfighter Tires No body shell on car Gradual rolling start to full throttle high speed tarmac passes Theoretical speeds listed from scriptasylum calculator Batteries were fully charged Temps were taken 2 minutes after last run Ambient Temp was 72f 20 minute cooldown between tests 2s 5000mah 40c Turnigy Max Amps - 165a Min Voltage - 6.99v Max Power - 1167w Theoretical Speed - 32 mph / 51 kmh GPS Measured Speed - 37 mph / 59 kmh Motor Temp - 110f 3s 5000mah 40c Turnigy Max Amps - 157a Min Voltage - 10.5v Max Power - 1670w Theoretical Speed - 48 mph / 77 kmh GPS Measured Speed - 53 mph / 85 kmh Motor Temp - 135f 4s 5000mah 40c Turnigy Max Amps - 159a Min Voltage - 14.7v Max Power - 2360w Theoretical Speed - 64 mph / 103 kmh GPS Measured Speed - 67 mph / 108 kmh Motor Temp - 145f I'm not going to try 5s at this stage I had a tire come off the rim half way down the street, was pretty scarey Though I would also see how hot I could get it After a 15 minute bash / wot tarmac runs, running 3s, ambient 80f Motor 175f ESC 145f Cheers |
cool data, nice breakdown format.
2360w!!!! 3.1hp. Cool.
I would love to see how the system ran if you geared for 45mph for each voltage. And I am very interested to see how it does on 5s without changing the gearing... |
I'd love to see the graphs, I'm curious as to the amount of time it spent at the peak amps.
Good info though, and man that's an insane speed on 4S for a short course truck!!! I wonder what kind of amps/temps you'd see geared for 35mph on 4S? |
| All times are GMT -4. The time now is 06:53 AM. |
