My truck / one moretry
I think it did!!!!!!!!!!!!!!!!!!!!!!!!!! A lot more work needs to be done on it...but it still is fun. Haven't totally got it complete and runnin yet. Still need screws that will fit the strobe. 4-40's DO NOT work, but i think i know which to use.....3mm's should. Also still need a ubec...
I can't see the pic cause it say I am not a member.
Same here, it doesnt work.
sign up page here aswell
darn, need to make them public...i'll get it in awhile...sorry.
try this... emaxx.livedigital.com
OK, try this... http://emaxx.livedigital.com/
It works now! Nice truck! Very neat wiring!
looks good, but here's a suggestion......you should switch the bl controller with the receiver.....this will cut down on wire length ect.....but overal it looks great....good.. job
Thanks guys. How do like the mod mount job that i used for the controller!!! Does my parrallel look right? it seems two neg wires will be going to one battery? is that correct? I still need a ubec though!
Also, the other question i have is, the wires that go into hte receiver. I'm not sure which ones the neg pos and so forth. i have orange, brown, and red think....so which way does the plug go into the reciever? Can you see it in the pics? Also, i pulled out the black jumper, do i need to do anything else to the controller?
your wires on the esc for the batteries looks correct....just make sure you have them like the following.....from the esc....black wire (-),(+)to(-),(+) red wire to esc......as for your other question....the brown wire should be in the rx the same way your servo wires are...ie...black wire on servo lead.....hope this helps....
i'll check it out. i won't need to pull any wires from the connector as i pulled the jumper out right?
correct.....
| All times are GMT -4. The time now is 03:27 AM. |
