-   -   Castle 1415 suggested gearing (https://www.rc-monster.com/forum/showthread.php?t=29378)
crusey_aus 02.20.2011 01:55 AM
Howdy Folks,
Just found this document
http://www.castlecreations.com/suppo...ring_chart.pdf
For a Slash 4x4 they reccomend
1415 (2400kv)
10-14t pinion with 54t Spur
1512 (2650kv)
16-24t pinion with 54t Spur
Is the 1415 info a misprint ?
14/54 would put it at around 32mph running 3s
Just curious
Cheers
lincpimp 02.20.2011 02:55 AM
I am guessing you want to run 3s with it. What battery do you plan to use?
crusey_aus 02.20.2011 03:12 AM
I'm allready running the combo mate was just interested why their suggested gearing range was so low compared to the 2650
I have done some testing and will probably run 17/52 (18/54) or so for bashing on 3s
Cheers
lincpimp 02.20.2011 03:42 AM
Well, the 2650 is larger diameter, so it is capable of more torque. However I think the lised gearing for the 1415 is convservative.
asheck 02.20.2011 10:55 AM
Since the 1415 uses the same rotor as the 1515 1y , same diameter only longer then the 2650, it should be capable of more torque.
crusey, I've been thinking about the temps you have seen. The only thing I can come up with is that the 2650 has more surface area to disapate heat. With 2 motors of equal efficiency, the motor with the most surface area should run cooler. But with the 1415 having the bigger rotor, it should be running more efficient at higher wattage.
I guess it's also possible that Castle had to lower the quality of the 1415, to get it in the price range they were shooting for, so maybe it is not as efficient.
FG101C 02.20.2011 11:22 AM
Are they intending 3s for the 2650 and 4s for the 1415?
crusey_aus 02.20.2011 06:00 PM
If you follow their suggested gearing ranges you would get the following speeds
2400
3s - 10/54 would be 22 mph
4s - 14/54 would be 41 mph
2650
2s - 16/54 would be 26 mph
4s - 24/54 would be 78 mph
Fairly large difference in their suggested speed ranges ?
Cheers
lincpimp 02.20.2011 06:36 PM
The 1415 has a smaller diameter rotor than the 1515. Pdel said it so himself..
So the larger diameter can 2650 will be able to disapate more heat, and will have a great output potential.
TBH I bet they are pretty close in overall power output. I am thinking the lower gearing is to help out the MMpro, as it will not handle as much load aa a MMM can.
I will pick up a 1415, when they get 5mm rotors. I have broken too many 1/8 shaft motors, in heavier vehicles.
asheck 02.20.2011 07:08 PM
I stand corrected, my apologies :) IIRC I had seen an earlier post where he said they were going to be the same, but doesn't look like that ended up being the best choice. quote from Pdelcast
Nno -- we used a little different rotor in the 1415 -- it's a little smaller in diameter than the 1515 rotor.
It was more expensive for the tooling, but we got better performance.
So they got better performance from a smaller rotor. Interesting.
aus, something else to consider with that gearing is the esc. Could be they are using the MMM with the 2650, and the MMP with the 2400. Though they still seem quite lop sided.
ta_man 02.20.2011 07:25 PM
Originally Posted by asheck (Post 398666)
I stand corrected, my apologies :) IIRC I had seen an earlier post where he said they were going to be the same, but doesn't look like that ended up being the best choice. quote from Pdelcast So they got better performance from a smaller rotor. Interesting.
I think what he meant was they got better performance with the smaller diameter rotor in the 36MM can (more room for copper in the stator) than they would have if they had used the 1515 size (larger diameter rotor) in the 36MM can,
Not that they got better performance out of the smaller motor than the larger one.
crusey_aus 02.20.2011 11:38 PM
Asheck,
Yeah you could be right mate it may be based on the ESC
I will change mine from 21/52 down to a 17 and take some more readings just to see what it does for amp draw etc...
Cheers
fastbaja5b 02.21.2011 12:01 AM
Curious what the MMP limit is tho, the SC8e RTR Brushless uses a 2200kv Neu 1515 1Y with the MMP on 4s Lipo, and yeah it works, but the ESC fan comes on a bit which indicates to me that it's a bit stressed.
crusey_aus 02.21.2011 12:22 AM
I tested geared 21/52 and hit 53 mph running 3s
Amps peaked at 165 or so
After bashing / high speed passes for 15 minutes the motor hit 175, esc 145, ambient was 77
Cheers
bruce750i 02.21.2011 03:49 PM
Did your speed top out? Sounds about maxed out for 3s. I've been running that motor with a good ol Mamba Max on 4s/ubec in a 4x4 slash, can't recall my gearing although:(
Bmr4life 03.14.2011 02:33 PM
That CC gearing chart doesn't make a lot of sense. They have higher pinions for motors with higher kv. It doesn't look like top speed is being factored.
I'm specifically looking at the Hyper 10SC and Slash 4x4 charts.
