outrunner size/kv for 1/16 summit ?
hi !
if i whant to replace the centergearbox and motor in a 1/16 summit truck with a outrunner motor ! how big does it need to be and what kv rating ? |
You can use the parameter solver to get motor kv value needed:
Enter your: - Enter the tire size - Enter the differential - Enter the battery voltage - Enter your desired speed (if you want to keep the same speed you have now, calculate your current speed using the Top Speed Estimator Calc). - For the transmission, enter 1 (outrunner is replacing this). - For the spur, enter 1 (outrunner is replacing this). - For the pinion, enter 1 (outrunner is replacing this). - Leave the motor kv value blank - Click the "calculate unknown" button. The motor kv shown will be the motor you need. |
After you find the kv via BG's method (listed above) I think a 28 size outrunner would do. The longer outrunners will provide more torque. You may be able to get away with a long 22 size outrunner. Not a ton of space to work with on the mini revo platform...
| All times are GMT -4. The time now is 11:24 AM. |
