My Stampede 4x4, with datalog of the Castle 3800
This is my Stampede 4x4. Running the Castle Sidewinder 3800kv. Trencher tires, Tekno driveshafts, modded bumpers, rpm arms, yada, yada.
http://pic20.picturetrail.com/VOL133.../395382606.jpg http://pic20.picturetrail.com/VOL133.../395382622.jpg Currently I'm running 11/54 gearing, a Gens 3s 5000mah 40c. Radared at 54mph. I just got my datalogger today, so of course I had to play, and the results were. http://pic20.picturetrail.com/VOL133.../395491470.jpg Temps were 125 esc, 130 motor, 50 ambient. As an educated guess, I thought it was going to pull 117 amps. Not sure if you can read it, but it pulled 116.8, with a pack low voltage of 10.38 :whistle: Of course I'm just figuring the datalogger out, but it's alot of fun. |
wow i didnt think the little sct esc was good for 100 amps, very nice logs
This sytem has been very impressive, so far. I started with the esc down in the chassis, and it was getting much warmer.
Here a little vid, of it doing it's thing. This is basically the kind of driving I was doing for the log. http://www.youtube.com/watch?v=9hlVG9EeqbY If you watch nothing else, the 1:00 minute mark is a must see. Truly displays this things power. |
great video
@ 0:40 :surprised: :lol:
Nice save! |
I am running the same sytem in a 2wd pede. Can you say no real load... I might have to give it a try in the 4x4 pede. Once I get the rear driveshats in...
My system runs ice cold. Motor does not even get warm. I am geared for about 45. The esc seems to do fine, ran it today but I ended the run with a flasjing amber light and steering only. Was that the lvc kicking in? Battery had not been charged for a while. |
I haven't seen that flasjing amber light on my CC ESCs before. Is it a new feature on the SCT system? I think it means you're having too much fun. You should make a thread in the Castle section so Patrick can chime in on it.
I did post a thread, thanks sweetie. |
Thanks guys, I'm glad you enjoyed. My plan is to find this motor's and esc's limits, which will lead to me testing the trucks limits. I tried to use the stock front shafts, they didn't hold up to a single backflip off the rock, go figure :)
I think the new sidewinder is a pretty good esc... But mine may have had an early death.
The motor has plenty of power. Good stuff, escpecially for the price. I paid around 93 bucks shipped. You cannot beat that. I will swap in a MM and really gear it up. Maybe low 60s. My lipo is up to the task, but I will have to setup the suspension alot better than it is now!!! And balance the tires. |
This motor is IMO a monster. I split it open when I first got it. Here's the rotor, next to the only one I had laying around, a Novak. But the Novak is actually a little longer then a standard 540 rotor, like the VXL.
http://pic20.picturetrail.com/VOL133.../395161535.jpg This thing has to be breaking records for the best bang for your buck :) |
I'm flattered that you used your favorite pet name with me, but you'll have some explaining to do when _paralyzed_ finds out. |
| All times are GMT -4. The time now is 05:08 AM. |
