Castle Bec Pro + castle link
I connect castle Bec pro with small wire "red and black only" than i connect it to castle link than connect lipos to supplies the power...and nothing on my pc screen. When i connect esc to castle link it works as it should..
All i wanna do is set the bec pro to 6V. :neutral: I got bec pro soldered to esc. When i spoke with castle, "the man" on the phone sad i can connect it to castle link even if i got it soldered on esc. Just use the power from lipos.. Am i doing anything wrong here? |
power it with lipo and then use the port on the top...
You need a male to male servo lead. |
1 Attachment(s)
I got the wire that came with CC bec pro. Male to male, got orange and black wire, no red wire.
http://www.rc-monster.com/forum/atta...6&d=1299942760 I powered the lipos than used port on the top and nothing... could my win 7 be the issue? |
Check this link, shows you what to do. No red wire because the BEC is being powered by external lipo, not the USB port.
http://www.castlecreations.com/produ...onnection.html |
Got it all set now, thank you very much!!
:party: |
| All times are GMT -4. The time now is 10:13 AM. |
