Glue??
Stamped..Q&A To glue tires down ..To rims What do I use???
and wipe down the bead of the tire with some alcohol to make sure you get good adhesion. That will help with the need for re-gluing later on... Losi glue works great.... Good luck
| All times are GMT -4. The time now is 10:25 PM. |
