little/cheap motor for 1/8 buggy??
I'm finding out that not having mec. brakes/biasing is a very fast way to get your ______ handed to you on a tight indoor track...
all of the parts are incoming, but I still need a smaller/lighter motor than the tekin 1400kv that I would normally use... It needs to be 1300-1900kv somthing like a 1412 would be perfect, but neu wants $200ish:surprised: |
ive got a 1512 3d if it would work for ya.
I have a 1512 1800kv motor if you are interested.
Nick |
You should check with jhautz. I was looking at the 810e thread on rctech and he was running the Castle 1410 on 3s.
I'm liking the leopard motor... does anyone have any experience with them??
is the tacon motor the same thing? and are all of these just fiago nock offs that will get uber hot? EDIT: an older medusa motor would be perfect I think... |
The Leopard and Tacon are the same, both 4 pole and basically castle knockoffs. Should run a bit cooler than the fiegao's. Might want to check Castle for their 14 series SCT motors, I'm unsure of availible kv's though.
it looks like mike still has a few medusa motors laying around... |
| All times are GMT -4. The time now is 10:21 AM. |
