electronics/BEC/transponder question
i have a servo that makes it necessary for me to use a BEC. however, it uses my last AUX port on my receiver and all i have left is the bind port and i still need to be able to plug in my transponder.
my questions are: 1. can i use the bind port for the transponder? 2. if not, can i run a Y harness between the servo and transponder or the bec and transponder? thanks for the help in advance guys. |
2) I would favour just using a Y-lead on either the servo or throttle channel, just in case the bind slot is a bit fussy about what is plugged into it.
thanks!
| All times are GMT -4. The time now is 03:12 AM. |
