Dimension Engineering regulator
Has anyone used this Dimension Engineering adjustable regulator? http://www.dimensionengineering.com/DE-SWADJ3.htm
I'm thinking about using it to power that 3S Turnigy HV servo for steering. |
Yes, I have one for R/c testing. You lose about 1.3v from the source power voltage. The pot adjustment is 360*=.5vdc
Will a standard servo plug fit on the pins?
Yes, it does fit.
| All times are GMT -4. The time now is 03:02 AM. |
