New Leopard 1/8 4068-3D 2950Kv motor, any feedbacks??
Hi guys I need to prepare my EMugen MBX6 for a tarmac race, I'd like to use on of these two Leopard motors: the well known 4065/2Y 2700Kv or the new 4068-3D 2950Kv motor.
-Is there anyone that knows the new 4068-3D 2950Kv one?? -What would you suggest me for a 1/8-1/10 tarmac track??? Tnx in advance :lol: |
The leopard motors seem good, so thats not a bad choice, but I wouldn't go over 2500kv if I were you. How many cells is this goign to be run on? What esc?
For pure speed/power if you need both motor and esc I'd go for a MMM/2650kv castle neu combo. That combo on 6s has been used by members here to get close to, most likely over, 100mph. Cheaper alternative would be toro esc/2560kv combo, but I have no idea if you could trust that on 6s. But for 4s its probably good. Thomas G |
Hi Thomas,
I'll use MambaMaxPro as Esc + 4S 40/90C 4000Mah Nanotech prop. :lol: |
The 2700kv leopard is going to be a rocket-machine on 4s, I wouldn't go higher in kv than that though.
Thomas G |
Actually it's my same idea, in using the motor intensely inside a tarmac track it keeps higher temps and going up in rpms will be a "straight drag race" matter, isn't it??
the 4065 is a great motor .......... I think the 4068 will be the same ......... or better ;)
Thanks x-y! :lol:
I can't find 4068 in leopard web site...
Very curious on any feedback about the motor :eyes:
Leopard make a massive range of kvs and motor sizes of the same basic motor design, so you may have to broaden your search to find someone using the exact same model you are researching...
Thanks ... I have find a table for 4068 motor . the 4068/3d max power around 2000w ... less than 4068/2y ...
LBP4068 Series Model MaxAmps MaxVoltage MaxPower KV Resistance No-load amp@7.4v Diameter×Length Mounting hole depth Length of Shaft Shaft Diameter (mm) Weight LBP4068/2Y 114A 21V 2400W 2350 0.0062 2.1A Φ39.8×67.8 7mm 18mm Φ5.0 345g LBP4068/3Y 78A 31V 2400W 1570 0.0134 1.3A Φ39.8×67.8 7mm 18mm Φ5.0 345g LBP4068/4Y 58A 42V 2400W 1180 0.0216 0.9A Φ39.8×67.8 7mm 18mm Φ5.0 345g LBP4068/2D 180A 11V 2400W 4390 0.0024 5.9A Φ39.8×67.8 7mm 18mm Φ5.0 345g LBP4068/3D 125A 16V 2400W 2950 0.0047 3.9A Φ39.8×67.8 7mm 18mm Φ5.0 345g LBP4068/4D 108A 22V 2400W 2220 0.0077 3.1A Φ39.8×67.8 7mm 18mm Φ5.0 345g |
| All times are GMT -4. The time now is 08:00 AM. |
