CRT.5 front arms
So I broke a front upper control arm on my CRT.5. The way it broke was 100% driver error.
Does anyone make a upgraded arm for the CRT.5? Other than the ones that Mikes sells, I can't see spending $175 right now eventhough I'd love those arms. Has anyone used another plastic arm off of another vehicle? Also, how do I get the upper arm off? Thanks for the help, Nick |
front upper?
most people just replace with a titanium turnbuckle and be done with it ;) |
As for arms, the SCRT10 has the same arms, if that helps you find them cheaper on ebay :) (or maybe upgrades) |
Thanks for the tip about the SCRT10 I will look into those. Thanks everyone, Nick |
http://i160.photobucket.com/albums/t181/dezfan/2173.jpg
http://i160.photobucket.com/albums/t...RT20_52010.jpg not my images, just examples of how the rie rod will install, 50mm rods are required with ball ends |
Does anyone make a full kit to do this or will I have to piece together all of the parts?
Is this the PBS suspention that OFNA sells? Thanks, Nick |
I asked about rear arms and they said "they are coming." Maybe if enough people ask about them they will come sooner. :whip: I haven't tried these arms because I want to just buy a full set when the rears are available. If you do buy the fronts, let us know how they work out. |
Here is a little update.
I ended up replacing the front plastic upper suspention arms with a set of these Traxxas turnbuckles. They are almost the exact size out of the package. http://www3.towerhobbies.com/cgi-bin...&I=LXSGY9&P=ML I had the truck out today running around a construction site and everything held up well. Nick |
thanks for the info. If I even run out of them upper arms I might just grab a set of those.
Ok, I replaced the upper arms as well as the steering links. So I figured i would share some pics. I was sick of the upper arms bending at the tiny turnbuckle, or breaking at the same point. I was also sick of the steering links popping off, or breaking the balls(lol)
I tested this setup pretty hard and its holding up extremely good. Best Part is it only cost about $14 total :D I used Traxxas TRA3644 for the Upper Arm, and TRA2444 for the Steering Links. Both are the perfect size, I didnt even have to adjust them. If anyone wants to do this and want instructions let me know, there are a few things you have to mod, but not much. Took me about 15 mins. This will also work on the SCRT10 Excuse the dirt, I didnt have time to clean her after the test runs. http://i70.photobucket.com/albums/i1...416_180331.jpg |
looks good Kylar!! I had a steering link pop off once, hope it's not recurring for me... :)
looks awesome :) instructions would be nice, looks simple enough but woul;d bed nice to see how you went but it ;)
Good luck, Nick |
| All times are GMT -4. The time now is 04:40 PM. |
