-   -   9920 no brakes (https://www.rc-monster.com/forum/showthread.php?t=2967)
easy 04.26.2006 11:25 PM
9920 no brakes
I just finished setting up and running a basic XL with a 9920 forward ,and reverse work great but it seems as if there are little or no brakes. Anyone else have this problem or have any ideas? thanks
bigabike 04.27.2006 01:21 AM
What radio are you using?
Serum 04.27.2006 02:01 AM
Yeah, it's a familiar problem, do a search for brake fade and you will see several posts about it. The 9918 is the exact same controller as the 9920, in case you didn't knew.
infinite_loop 04.27.2006 02:58 AM
Mine has a brake fade problem as well...
Seems to happen after about 5-10 minutes of running.
Has this problem ever been solved? I've found posts about it, but never read about a solution (if any)...
Serum 04.27.2006 03:03 AM
There is one specific component that get's hot, it is solved, but i am not sure what component it was/is. Dafni knows the entire story.
PM him if you want to know.
bigabike 04.27.2006 03:33 AM
My problem was that I programmed the ESC with the stock radio set at 70/30. Reprogrammed at 50/50 and problem was solved.
easy 04.27.2006 10:03 AM
I programed eith a Futabu FM radio, my brakes don't fade when it get warm or hot. they are gone almost within 20 or 30 seconds. I will try and program it today with my spectrum radio today and see if that helps
neweuser 04.27.2006 04:35 PM
Mine 9920 does the oposite...my brakes are way touchy, i think i just need to adjust the radio though...
coolhandcountry 04.27.2006 06:45 PM
Dafni had this problem. I think he got his esc replaced. I am not sure what all it was doing.
sjcrss 04.27.2006 07:54 PM
Neweuser....the email I sent you.....you say your brakes are to touchy...make this adj. on your radio.....remember the email I sent you with the radio adj....go to button (A) and adjusting it down from 80 will make it less touchy...if you go up to 100 it will instantly apply the brakes if you even just barely let off the throttle.......so in your case....go down from 80....my suggestion is do it in increments of (5)....and once you are some what happy with it go up or down a few #'s till you find it where you really like it.....any questions you know how to find me....
neweuser 04.28.2006 03:21 PM
thanks, cured the problem!!! brakes are less touchy and throttle is a little more responsive! If i can get my batts to stop stuttering, this will be a very smooth system.
