Torque Control Question
I recently picked up a SCT/3800 combo and paired the 3800 motor with a Mamba Max I already was using in a Rustler. The motor is AWESOME with TONS of torque, in fact too much torque for a 2wd Stadium truck. So I did the motor test and enabled the torque control and set the value to 7.5 for a trial run. The torque was reduce but still too much but my ESC temps went up from ~120º to ~155º. Is this normal and will lowering the value to reduce torque more drive the ESC temps even higher?
your sig mentions a 5700kv motor. Did you change gearing to compensate for a lower kv? Perhaps you are undergeared and not presenting enough load to the motor?
Geared correctly the torque control shouldn't affect temps that drastically. |
Yes the gearing was changed from 18/86 to 25/86 and then to what it is now 28/86 when the motor was changed. The motor is staying very cool, it is typically around 105º to 110º at the end of a 5000 mah 2s lipo. It is the temp of the ESC that I am a little concerned about as using the torque control feature in Castle Links seems to be driving it up and I am wondering if that is normal.
torque control can be similar as a partial throttle, and the ESC does'nt like partial throttle...
| All times are GMT -4. The time now is 02:41 PM. |
