HPI E firestorm Flux updated again, now with a 4 pole motor
http://www.hpiracing.com/kitinfo/105878/
Towards the bottom of the page 4800kv 4 pole, now 3s capable as well. Nice to see some progression in the electric rtr world, make a nice beater |
a rustler killer:yes:
you left out the best part! It's waterproof! Now I can just get it soaking wet and hose it off and be done with it, har har hardy har derp.....
Personally i think the E-firestorm has been the rustler beater since getting the BL setup. Loosely based off the T4 associated, but with more flexible pieces |
Saw a typo. 2.3mm 1/8" shaft.....
I noticed that the motor has "A B C" printed on the endcap. Does this mean there is a possibility that there will be a sensored version coming out soon? I can't think of a reason why those letters would be needed otherwise, especially since you can change direction simply by swapping motor leads or via software...
Sensored versions of this motor (and some lower kv models) would pair up nicely with a MMPro... |
That's a pretty intriguing ready to run.
It has pretty much everything a basher or 1st time needs, and it is more than ready for all sorts of fun. |
^^ agreed. I def like the stock dogbones
Small sensored 4 pole motors is what I'm waiting for.
ooh sensor this sensor that. Why is everybody so sensortive?:rofl:
ooh, I got to check it out. Bummer I just got a sensorless aveox motor. Sensored setups are cool in low voltage setups and Cheat mode.
| All times are GMT -4. The time now is 05:42 AM. |
