-   -   Fan Mount (https://www.rc-monster.com/forum/showthread.php?t=2976)
bigabike 04.28.2006 03:32 AM
Fan Mount
I am not a master fabricator like many of you, but I thought I would share the fan mount I made tonight. It ain't perfect, but I am pleased with the results. It is made out of aluminum with a 5v fan plugged into channel 3 on the Rx. I blows a lot of air on the esc and motor.
Mount without fan.
http://www.rustyonline.net/assets/images/fan1.jpg
Mount with fan.
http://www.rustyonline.net/assets/images/fan2.jpg
Dafni 04.28.2006 03:36 AM
Cool! Literally :)
bigabike 04.28.2006 03:48 AM
Thanks Dafni.
Nick 04.28.2006 05:55 AM
Looks good! Stylish fan there.
How is the mount held up? What is it fastened to?
HotnCold 04.28.2006 06:49 AM
How many mm is that fan - it looks big - 60mm? - should keep things cool in any event...
coolhandcountry 04.28.2006 07:18 AM
I like that you even put the guard on it. Cool! Nice job. You may not be a master craftsman but you did nice on this. Hard to see if it is perfect at 30mph with body on it. The faster the harder to. :D
Sylvester 04.28.2006 10:22 AM
Very nice! It looks similar to the one im using, only difference is my fan is a DC brushless (12V)
Mike.L 04.28.2006 10:44 AM
nice work. if you could bend the alunimum a bit so its a bit closer to the motor. but its sweet
bigabike 04.28.2006 11:12 AM
60mm. You have a good eye.
bigabike 04.28.2006 11:37 AM
Thanks guys.
The ESC is sitting on a shelf made from a flat skid plate using FLM shock stand-offs to get it up off the chassis. The fan mount is connected to the holes in the skid.
UBEC is mounted under it with strong double sided tape.
http://www.rustyonline.net/assets/images/fan3.jpg
