Is there any difference
Between reversing the motor wires or changing the direction in the Castle Link program?
no difference
There's a difference, if your direct soldered then it's a hell of a lot easier to change it in the programming. If you use bullets, it's easier to swap the wires. :intello: :na:
From an operation standpoint, there's no difference. However, if you want a specific color order for aesthetic reasons, then the easier way is through software.
| All times are GMT -4. The time now is 02:41 PM. |
