Need to know if this will fit a savage
Im thinking of ordering this servo but need to know if it will fit since it is taller than a normal servo. Has anyone used it?
http://www.nitrokings.com/index.php?...oduct_id=31644 |
Flux radio box has 30mm clearance from the mount point to the bit of plastic that would hit the base of the servo.
Looking at the diagram here http://www.savoxusa.com/ProductDetai...Show=TechSpecs it doesn't have the dimension from the base to the mount point like some of their other servos. Doing a rough proportional calc though off the diagram I get about 31mm. So likely you would have to modify the radio box. Btw, that servo is brushed not coreless. |
Homework...
Don't have a Savage myself, but do some measuring and compare. Here are the measurments from that link. What do you have room for? I am sure that you can make it work if you are willing to do a little fab work on your own. It looks pretty close from what I read.
40.7x19.6x42.4mm |
Thanks guys. I think ill just buy a normal size one, looks like i will have to do some mods to get that to fit.
| All times are GMT -4. The time now is 06:48 AM. |
