Upping Cells
Well, I'm going to redo my ole IB's, but now since i have them apart, i'm looking at going with 20 cells now...why not! The problem i see with that is fitting them in the stock chasis. Any ideas on how to do this? Maybe go 18?
You can make them 6 cells and than add the extra 3 cells onto the top, so its like a hump, you need GMAXX straps for that to work, everything else should be fine.
That's what i thought...thanks! So hump them in the middle? Or the end? Diagram perhaps? thanks man...speaking of diagram, how do u guys do that on here?
Well make sure it don't hit the trans. You have to do a weird kind of pack. I not sure how it would work out. I seen one with the 3 cells run down the side of the pack.
Would you happen to have a link where i could figure something out? I thought about going down the side, maybe just do them along the side like the end one would be with the 14 cell pack? hmmm, i'll hump them i think instead, might be easier, just get straps! that sounded kinda bad i guess huh?!
i have seen people cut the bottom slots out of the stock chassis and put the extra cells on the bottom instead of top for a lower cg.
| All times are GMT -4. The time now is 10:42 AM. |
