-   -   Mamba XL or HV160 (https://www.rc-monster.com/forum/showthread.php?t=29807)
_paralyzed_ 04.15.2011 10:25 PM
Mamba XL or HV160
I'm debating. I put the Mamba XL I had in my cybermaxx (1521 on 8s:yes:) and need to buy a new ESC for my 5b.
I'm running a RX pack and mechanical brakes just because. I rarely use reverse. (leftover driving habit from nitro days)
Do I go with the HV160 and have the ability to run up to 12s or just go with the XL as it has car specific software.
I can get an HV160 and a pistix for about $50 less than an XL.
Anyone?
What's_nitro? 04.15.2011 10:27 PM
Mamba XL.
Just because I like the 8AWG wires. :mdr:
bigsteel 04.15.2011 10:34 PM
Id say hv160 just because you can run 12s (insane).upgraded brakes work fine on a Baja and reverse is for wussies!
Dj_Sparky 04.16.2011 03:10 AM
What motor do you have in your Baja? If it can handle 12s then that's the way to go.
Also, do you need to program it in any particular way to get it to work with a car, or is it just plug n play?
_paralyzed_ 04.16.2011 03:23 AM
The CC 2028. It's only rated to 8s. I want to push it. (obviously voiding warranty)
Other than adding a pistix to the HV160 it is plug and play.
brian015 04.16.2011 05:57 AM
Originally Posted by What's_nitro? (Post 404340)
Mamba XL.
I like 8AWG wires and running my truck on 10s - that's why I use the HV160.
(My next large scale will eventually run the Mamba XL - but last summer it wasn't available - and I didn't want to wait)
What's_nitro? 04.16.2011 07:10 PM
Oops... I didn't know the HV160 had 8awg wires ..... :smile:
DrKnow65 04.17.2011 01:09 AM
I have both the XL and a Phoenix ICE HV. I spend lots of time driving both.
I would give up 12S and live with the XL in a heartbeat.
Why?
XL has proportional brakes (eliminates brake servo, disc hardware, and gives software adjustments)
XL has internal BEC (perfect for a single servo RC, no CC BEC or receiver batt and simplifies wiring)
XL has better software as far as current limiting, brake & throttle curves, BEC voltage, punch control, ect
XL has integrated fan, though I have copied closely on my ICE
XL has mounting options OTHER than servo tape/ Velcro
brian015 04.17.2011 06:48 AM
Why?
I'm not arguing - just responding:
1. ESC braking and reverse are obviously a major draw on the XL.
2. But with all the XL failures - I think most would now run an external BEC on a large scale vehicle.
3. Agreed - but I've had no complaints about the drivability of the HV160 in my truck - of course, I'm the type who doesn't change many settings on my MMM's.
4. I've never seen temps high enough on my HV160 (even in summer) to worry about a fan.
5. I have my HV160 mounted through the screw holes on its case.
SV6000 04.17.2011 08:03 AM
How about the Hydra ICE HV
_paralyzed_ 04.17.2011 11:36 PM
All good food for thought guys, thanks! Any more thoughts/suggestions?
Brow 04.18.2011 12:01 AM
Go for the 12S - they are all toys so go for it and play hard!!!
_paralyzed_ 04.18.2011 12:26 AM
Sir, I like your way of thinking!!:yes:
_paralyzed_ 04.18.2011 12:33 AM
Why?
Good points Dr.Know, thank you.
I'm going to run mechanical brakes
I'm going to run a rx pack
I never use the castle link I plug and bash
I'm replacing the fan on my XL with a clear one so the XL fan can be used
Maybe you have an older HV or less than a 160? They currently share the same case as the HV160
I've decided to go HV160!! I'll then have one of each.:yes:
Brow 04.18.2011 02:38 AM
Way to go dude. I have a 2 speed dragster project (very early stages and long term project) and I have been looking at possibly using a HV160 or similar but I can't afford one at the moment. By the time I get the funds and am ready for an ESC I am hoping there are more options and maybe higher HV too. I will need funds for batteries too!!! I have 6s in my Savage and sort of think I should have bought one of Lutachs 10s ESC's instead of the 6s.
How about this Neu motor?
4440 1Y 63KV 12KRPM 15000 watts 30000 watts(peak) 200 volts
Just need to find an ESC for it and gear it to the moon. Going to need at least a restricted electrical licence too!!!(in Australia anyway)
