ubec wiring it up
I just got it today. I'm not sure, can one of guys go onto ebay and check that one out...just type in ubec and it'll come up. But man, it's so small. am i suppose to cut female connector off from the female connector that goes to the batts? and when i do that, do i just solder them to the controller wires that go to the batts? Is this thing gonna handle the voltage?
The hot to hot and ground to ground.
You have the idea. It is pretty simple really. It should handle the voltage pretty well. |
OK, thanks coolhand. I have a novak fan, can i wire that together to the ubec wires then to the controller to batts?
i have the same ubec. just got it actually. what i plan on doing is leaving the connector and just getting a male to solder to my deans since the lead is so short. thataway it can be removed without unsoldering.
Cool idea man. I have a male from JR receiver pack that i cut off. But my question: I have a novak fan with a male connector also. Can i cut hte male connector off that and hook that in to ubec somehow?
If you not using the 3rd channel could plug in there.
You can get a y connector and run it on that. |
Thanks coolhand!
| All times are GMT -4. The time now is 10:14 PM. |
