-   -   Upping performance of Truggy servo (https://www.rc-monster.com/forum/showthread.php?t=29884)
Big House 04.23.2011 11:17 PM
I need a little assistance in getting better performance out of my servo or should I drop the one I am running and find another one. I am currently running a servo from PPP Servos. It turns my truggy pretty good but my Jr turns my GTP much faster. The both cars run the same MMM and receiver so how can I boost the performance to the servo without switching. Thanks.
What's_nitro? 04.24.2011 02:04 AM
All I can think of is to run a higher BEC voltage.
Big House 04.24.2011 03:37 PM
Is that as simple as running a separate power source to the receiver. If so that is an easy fix...weight is not a problem.
DrKnow65 04.24.2011 04:04 PM
In the programming for the MMM one of the settings is BEC voltage. Make sure you don't exceed the rated voltage of the servo though.
I set all my standard servos at 6v.
BrianG 04.24.2011 04:10 PM
Since 6v servos are meant to run off 5 NiMH rx packs (for those nitro guys), and a 5 cell NiXX pack can be around 6.5v (1.3v/cell) for a while before the voltage settles to the nominal 1.2v/cell, you could get away with setting a BEC voltage of around that and be fine.
Big House 04.24.2011 09:25 PM
BEC settings...
I am connected to Castle Link and I don't see an option to adjust the BEC voltage. Am I missing something here? Please let me know. Thanks.
simplechamp 04.25.2011 12:19 AM
DrKnow must have been thinking of the MMP which has an adjustable BEC. The BEC on the MMM can't be adjusted.
Is this the servo you have?: http://www.rcuniverse.com/magazine/a...rticle_id=1053
If that's the case I'd say you'll need to upgrade to a servo with more torque. It's rated for 208 oz-in, most people run 300+ oz-in for truggies. The Hitec 7955TG is somewhat of a "reference standard" for truggy servos, but there are plenty of others out there that will do the job. Savox are becoming very popular. Personally I use a Turnigy HV767 on 7.4V and it's a beast!
BIG-block 04.25.2011 09:07 PM
Me too. I really like that servo. Power and speed are pretty good even though I have it on dads Erevo with Axial oversized wheels and Big Joes tires. Even when I press the front of the truck down to the ground with my foot the steering moves just as fast as when it is off the ground. Also I am running it @ 8.2V via CC BEC. No issues what so ever. I believe the servo is a MKS rebranded to Turnigy. There are even rebuild gears from MKS that fit straight in. Going to fit one to my RC8T truggy as well.
With most 6V servos I have ran them with a 2S LiFe packs back in the nitro days with no real issues. The 2S LiFe pack is about 6.8V fully charged and my ACE1015 servos performed much better than with Ni-MH pack. I think that most decent servos can take about 0.5-1V above their 6V rating.
