-   -   mmp leds blinking (https://www.rc-monster.com/forum/showthread.php?t=29918)
dracbec 04.29.2011 05:10 PM
mmp leds blinking
all the leds on my mmp are blinking and its brand new and i cant calibrate or anything....i already updated the software and turned off the lvc just in case it was something like that.....oh and the fan runs all the time?
anyideas asto what could be wrong?
suicideneil 04.29.2011 07:50 PM
http://www.rc-monster.com/forum/showthread.php?t=20020
Flashing all colors = speed control is not receiving a valid signal from the receiver, usually indicates the receiver wire is plugged in backwards into the receiver; possible problem with controller or with throttle channel on receiver.
Check your rx plugs & leads, and the transmitter batts.
dracbec 04.29.2011 08:37 PM
i have done all of that even a hole diffrent radio system
E-Revonut 04.29.2011 11:58 PM
Don't take it the wrong way but is it plugged into the rx correctly? I have accidentally plugged my esc into the rx backwards before and iirc that is exactly what mine did. Make sure the tan wire is in the - position, usually to the outside of the rx
dracbec 04.30.2011 12:05 AM
yep checked that and even turned it around to make sure
suicideneil 04.30.2011 01:35 PM
Hmm, check the throttle trim & epa settings maybe- you might also need to try reversing the throttle channel.
