-   -   HALP!!!!! MMP+medusa 36-60+6s=... (https://www.rc-monster.com/forum/showthread.php?t=29919)
whitrzac 04.29.2011 07:33 PM
with the latest 1.32 software on the ESC I get nothing but cog, as in the motor vibrates slightly when gas is applied. With 1.26 everything works fine....:neutral:
suicideneil 04.29.2011 07:45 PM
Its an extremely common issue- any firmware newer than 1.24 can cause terrible cogging, but it doesn't seem to happen for everyone however ( may be dependant on the esc revision, maybe not ). Since there is little to be gained with the later firmware versions ( besides torque control mainly ) I would suggest staying with the last version which works correctly for you.
