-   -   MAMBA MAX PRO ????'s (https://www.rc-monster.com/forum/showthread.php?t=30000)
jas21373 05.14.2011 10:50 AM
hi ,is any one using the mmp sensored in a 1/8th buggy on 4s???
Was thinking of running a mmp esc and a tekin 2050 kv on 4s in a Losi 2.0 buggy.Would this be ok?
cheers jas
Bondonutz 05.14.2011 05:08 PM
Absolutely !
jas21373 05.15.2011 12:17 AM
Originally Posted by Bondonutz (Post 406498)
Absolutely !
any ideas on setup.......timing ,gearing etc..etc..
pinkpanda3310 05.15.2011 09:22 AM
You'll be geared for racing on a tight track won't you Jason? I don't think you'll have any probs, the losi is light.
What do you currently use, the monster or tekin? Either way I bet the fan doesn't even come on.
jas21373 05.15.2011 10:09 AM
hey mate,yeh running at carine ,my losi got the monster and neu 1512/2.5df but I want to try a sensored setup,Ive had the mmp for awhile now so thought I might hook it up to a tekin 2050 kv.
pinkpanda3310 05.15.2011 07:08 PM
Sounds like you won't loose any runtime moving to that setup because it'll be a slightly more efficient motor IRRC.
I meant to catch up with you over easter but ended up busy. I'm not sure when I can make it next.:sleep:
jas21373 05.16.2011 06:31 AM
Thats go to know ,I get two 7 minute heats out of a 4s IP 5400mah now.If I like the setup I will look at changing the truggy too.
Yeh ,will have to catch up
