-   Fastlane Machine (https://www.rc-monster.com/forum/forumdisplay.php?f=22)
-   -   A "how to" for the flm emaxx chassis??? (https://www.rc-monster.com/forum/showthread.php?t=30032)
dtnel 05.20.2011 12:41 AM
:rules: Does anyone know of or where there might be a how to for installing the emaxx on the flm chassis. We're talking the 3903/3905/3908 spec. Any help would be appreciated as this will just make the install easier to do. Is there anything that I currently have on the stock 3908 won't fit on this chassis either?? Thanks for the replies aheadf of time. :rules:
:rules: :rules: :rules: :rules:
ZippyBasher 05.20.2011 12:53 AM
:rules::rules: What exactly is the problem? :rules::rules::rules::rules: I have the chassis and have built it.....:rules:
How can I help?:rules::rules:
Remove Screws and chassis, Insert new chassis. Tighten...:rules:
dtnel 05.20.2011 01:19 AM
The chassis came with a bunch of screws so I'm wondering do some of them replace some of the current screws or are they for the battery straps that are in the chassis bag as well?
I haven't opened the 2 bags yet but was just trying to come up with a game plan in my head.
Other than my first question in this post does everything else just "swap" over to the new chassis with a good fit or are there stock parts that don't fit which are going to require me to purchase addl parts to complete the switchover ?
swiftneed 05.20.2011 09:00 PM
THATS A GOOD QUESTION i am wondering i purchased it also and am wondering if the shafts are a different length and furthermore i would like to use the RCM center diff as a transmission but how
ZippyBasher 05.20.2011 11:47 PM
You guys are way over-thinking this. take out all the screws that have to to do with the chassis. and apply the new chassis. The only weird part is the ribbed metal tube that takes up the spot on the chassis where the steering posts go. Just mimick the plastic version.
The Driveshafts will fit perfectly with supplied cups. They will be too short with the CD mount as the trans cups are further spaced than a 1/8 CD. I used a XXL Rear Dogbone on my CD Maxx with FLM Chassis monoblock. So I think something around 105-110mm long should work with no Mono for the rear. Thread is avail on my sig.
And By the Way The FLM chassis and dirveshafts are some beefy and seriously great Additions. 2 years beating it with 6s and the cups look new and the shafts are worn but still work fine. chassis still looks shelf queen worthy.
dtnel 05.21.2011 12:10 AM
I just wanted to know what the screws and little aluminum piece that isn't the post that came in the plastic bag are for?? Are they just for the battery straps or is there addl pieces (screws) that are for the swap over?
Looking at where the bulks mount up and stuff it appears that the diffs from the stock bolt right up as it appeared from when I looked at it out in the garage still in the bag. Don't want to open it until I'm ready to build it so I don't lose the screws in the bag.
It's still in the bag till Tuesday when I can work on it with the way things are here around the house. To many graduation open houses to go to this weekend..............
Thanks for the other info as well.
coolhandcountry 01.12.2012 01:56 PM
Did you finish this chassis swap?
Emaxx_Quebec 01.12.2012 05:18 PM
If I understand correctly, I use those peices on top of the chassy to mount my UE saver!
http://i265.photobucket.com/albums/i...CF0005-3-1.jpg
Fred
