-   -   Help needed with pics, Motor Neu (https://www.rc-monster.com/forum/showthread.php?t=30094)
Jony Nitro 06.02.2011 03:20 PM
Hi guys need a bit of help, doing a brushless baja, bought the motor, had a look at another baja build, and it seems is shaft length is short my one? and the other one seems longer does Neu make diiferent size ones, as when I ordered it I am sure there was no longer onbe available
thanks Jony
http://i465.photobucket.com/albums/r...2/SAM_0448.jpg
brian015 06.02.2011 05:44 PM
Neu's site lists the standard shaft length as .75"
http://www.neumotors.com/Site/2200_series.html
I've never owned a 22xx series motor - but I've seen pictures of ones that appear to have longer shafts than yours - like this one (from OSE's site):
http://www.offshoreelectrics.com/pro...2215-motor.JPG
:neutral:
suicideneil 06.02.2011 11:17 PM
I would contact Neu directly and see if you can get a replacement rotor with a longer shaft- there are so many different versions of cans & 2 shaft size options ( 5mm & 8mm ), it may be that the longer shaft version is for a specific purpose vs the regular .75" version you seem to have...
_paralyzed_ 06.03.2011 03:29 AM
it's not a problem, just put the setscrew on the pinion facing the motor
Jony Nitro 06.03.2011 04:25 AM
mm don't think so, it would,nt fit
http://i465.photobucket.com/albums/r...2/SAM_0458.jpg
http://i465.photobucket.com/albums/r...2/SAM_0457.jpg
suicideneil 06.03.2011 11:00 AM
Harold means install the pinion so that the tooth-side is facing outward, and the side with the set-screw is closest to the motor- you may have to hang the pinion off the shaft a little bit but give it a go and see how it looks.
Dj_Sparky 06.03.2011 11:24 AM
Which motor is that anyways?
_paralyzed_ 06.03.2011 01:13 PM
love those innovative shocks!
x-y 06.04.2011 02:22 AM
with the photos I think is possible work good ........... ¿you tried to put the pinion on the motor shaft?
