Hard to find bearing size.
I'm looking for a bearing that measures 8x17x6mm. (17mm diameter, 8mm hole, 6mm thick) I can't seem to find one anywhere. I've looked at ebay, avid, bocca, and acer. :whip: I need four for a project on my e-revo.
Any suggestions? Edit, I was able to find my desired size on google, but they are $25 a pop............ |
You could use a shim (aluminum foil) around an 8x16x6 bearing which is more common.
Edit: 8x19x6 is also common... |
Good idea, but these will be the outer wheel bearings in the revo knuckles. Not sure if I want to go that route. Now why did Hot Racing have to go and use a 17mm bearing. :no: |
So they could charge you $25 for it. :yes:
Wait...which HR knuckles? The only ones I see on their site use the 6x13x5 bearings...
The knuckles I have use 6x17x6 bearings. I'm wanting to use Losi XXL driveshafts. That's why I need the 8mm bore. I wouldn't mind using a 8x16x6 bearing, I just wouldn't want to shim it with aluminum foil. Is there a better shim option out there? I'm not sure if a metal sleeve that is .5mm thick and 17mm in diameter exists? |
24 AWG sheet is 0.51mm thick. :wink:
Pardon my ignorance, but do mean like this:
http://cgi.ebay.com/Mirror-Polished-...item23114842ca I couldn't find anything under 24 awg sheet. |
Yeah, it seems using "24 AWG sheet" as a search term doesn't turn up anything useful...
I'm not sure where you're located, but if you're in the USA I'd go here: http://www.onlinemetals.com/merchant...=76&top_cat=60 Or, if you would prefer stainless, that item you linked to will work fine. It will be harder to form, though. |
Thanks, I'm in the US so I'll look into them. :yes:
| All times are GMT -4. The time now is 02:27 PM. |
