-   -   Li-Po? (https://www.rc-monster.com/forum/showthread.php?t=3016)
highhat 04.30.2006 05:26 PM
Li-Po?
What is the minimum recomended rating for Li-Po's?? 10C, 15C, 20C etc..???:032:
Sylvester 04.30.2006 06:17 PM
For a 1/10 truck such as an emaxx they shouldnt be lower than 15C.
highhat 04.30.2006 06:50 PM
Thanks Sylvester
So 15c for my E-Zilla but if I go Brushless on my Savage then 20c?
MetalMan 04.30.2006 08:34 PM
C rates don't mean anything without the capacity factored in...
If you have an 8000mah 8C pack, that can handle 64amps continuously. If you have a 3200mah 20C pack, that can also handle 64amps continuously. The 8C will obviously give you more than twice the runtime, but it will also weigh more. My point is that C rates aren't all that important. Don't go out and buy a pack just because it says 15C or 20C.
I run an 8C 5400mah (43amps continuous) in my 1/8 buggy, and that holds up fine. Recently I bought an 8C 6600mah battery that I have yet to try.
