New 4 pole motor?
A friend pointed out to me this brushless system:
http://www3.towerhobbies.com/cgi-bin...?&I=LXAZUP&P=7 http://www.duratrax.com/caraccys/dtxc3122.html The controller appears to be a sidewinder but the motor doesn't match any in Castle's current lineup. Can anyone give some info about this motor? Avner. |
they must have built that motor specifically for duratrax to their specs
Hehe my evader has been castle powered for awhile.
Another Neu 1406 variant ?
Cheers |
I don't think it's the Neu-Castle 4-pole design. Looks more like the older 2-pole CM36 Castle motors, before they updated to the rebuildable style. HPI had a system just like that OEM'd by Castle, their Motiv/Warp combo.
Being a 4-pole, It looks to be based on the 1406, but probably uses some cheaper materials. I wouldn't expect the same quality.
2mm is nothing, and if look at them you notice the duratrax version have screw on the body for holding the front bell and in the original castle version the screws are countersink in the front, making it longer. |
I recently bought this setup for my 2s Rustler. The MMpro was just overkill just to run on 2s. I didn't use the motor, but it looks to be of decent quality. I'm using an 8L C40 Hacker motor with the Element/Castle ESC. The motor gets warmer then the ESC!
Nice part is that I can use the Castle link to mess with the settings in the ESC. I do miss the adjustable BEC, but it's like running the MM now. There is also no power switch and the warranty is only 120 days. |
| All times are GMT -4. The time now is 01:32 PM. |
