-   -   Stock Chassis (https://www.rc-monster.com/forum/showthread.php?t=302)
Nick 03.14.2005 01:55 PM
Stock Chassis
I will be going brushless this year, I am thinking of the 9918 control and 9L Motor. I will be running 14 cells 3300.
My E-Maxx is currently all stock.
What NEEDS upgrading or buying to handle the brushless system?
What do you think should be upgraded?
I hear about certain bits need strengtening, to alloy. I also hear about a battery for the servo? How would one fit?
Many thanks,
Nick.
thunderw0lf 03.14.2005 02:32 PM
I think the best thing to do for upgrades when you go to a more powerful motor is do the upgrades as things break. I know this sounds like a pain and sounds like a lot of down time but you'll save money not buying a part that is strong enough. I'll be switching to a brushless in my Stampede shortly and figured a number of things would need to be upgraded to handle it but from reading on the forums, I see many people that still run a lot of the stock components and haven't broke them in a year of abuse. One thing I did do right off the bat was get an aluminum idler, the plastic ones are easy to strip with anything stronger than a stock motor. You might check the Traxxas forum for suggested upgrades though.
HotnCold 03.14.2005 02:37 PM
Welcome...
Welcome to the site Nick. I see your interested in the 9L and 9918 warrior - if you are going to be running 14 cells that is close to the rpm limit of the motor. You probably want to upgrade the drivetrain first - CVD's, diffs, idler gears. That is what i would start off with for now. As far as for the battery for the servo - RC-Monster offers a UBEC - so a battery is not needed for the servo - your servo would get its current from the 18 cells - It dosent use a great deal of power and it beats having to charge your receiver battery all the time also. These are a few things to think about.. Hope this answers a couple of your ?'s......
MaxxFusion 03.14.2005 02:48 PM
Here are some links to the parts you will need.
SuperMaxx E-Maxx Hardened Steel Idler Kit
This is the center CVDs needed for the extended GMAxx chassis:
SuperMaxx Titanium Center Driveshaft Kit, EXT Electric Chassis
Maximizer 7075 Aluminum Diff Cups
Integy Aluminum Diff Case
Integy Gear Box Collar
Maxx 2.5 Cvds by RD Logics
Nick 03.14.2005 04:22 PM
That is brilliant thanks!
I am still confused about having a battery pack for the servo? You say I don't need one? I also read somewhere about interfernce with a brushless system and another component on the stock E-Maxx? Thanks in advance to anyone who can help me out on that one.
What sort of guarntee/warrenty do I get from a Feiago 9L and 9918?
Thanks! :D
HotnCold 03.14.2005 05:15 PM
No receiver pack
http://www.rc-monster.com/proddetail...=6vubec&cat=21
Check out this - It this eliminates the need for a receiver battery - as for the warranty - ill let RC-Monster Mike respond to that...
RC-Monster Mike 03.14.2005 07:01 PM
The Feigao motors are warrantied for 2 years against defect. The controllers for six months (I think-not sure). BK is good about taking care of business, so if something happened that wasn't your fault, I doubt you will have a problem getting it serviced (haven't had any problems yet).
Nick 03.15.2005 03:56 AM
Thanks.
I am really pleased on how quickly and well you have responded, I have being trying to get answers for months on other forums, and I got them all in 1 day here! :)
HotnCold 03.15.2005 07:12 AM
Answers
You mean it took a full DAY - C'mon guys - were falling behind on our replies - LOL :) :)
Nick 03.27.2005 07:05 PM
Could someone tell me how many I would need to order of each for the E-Maxx? I guess some things I need more than 1 in the basket? :)
Thanks,
Nick.
MaxxFusion 03.27.2005 10:34 PM
1 - SuperMaxx E-Maxx Hardened Steel Idler Kit
1- SuperMaxx Titanium Center Driveshaft Kit, EXT Electric Chassis
2 - Maximizer 7075 Aluminum Diff Cups
2 - Integy Aluminum Diff Case
2 - Integy Gear Box Collar
2 - Maxx 2.5 Cvds by RD Logics
lipomax 03.27.2005 11:35 PM
I replace parts as they break or as I feel like I want the next upgrade. I finally took the plunge and got the Gorilla Max carbon chassis. It weighs over 1/2 oz less than the stock chassis. But I got it so I can lower CG and the choice of batteries is greater too.
