E-Maxx 3905 Extended Chassis vs Extended E-Maxx Chassis
What is the difference between thoose 2?
What i can see on my truck i got the 3905 Extended chassi, but the other one, extended 35mm... is it longer then mine?,does it fit my parts that i do have (got all FLM on the truck) /T |
Jag hade samma mittlina på båda mina så dom borde ju vara lila långa.
The normal extended chassis is only for the old 3906 transmission, the 3905 version only works with the new emaxx transmission- they should be the same length give or take a few mm.
Tack Rickard, and thank you Neil, just woundering..soon off for some bashing action
| All times are GMT -4. The time now is 01:34 PM. |
