-   -   DM-1 from nitro to brushless (https://www.rc-monster.com/forum/showthread.php?t=30270)
rc hobby 07.11.2011 03:09 AM
Hi im new to all this brushless/electric stuff
i have dm-1 1/7 that i would like to converted to electric my goal is to make it as fast as i can may be 100 mph? if posible
so i will need all help i can get
http://i232.photobucket.com/albums/e...1/IMG_1065.jpg
http://i232.photobucket.com/albums/e...1/IMG_1066.jpg
sorry for the iphone quality
I dont have any parts yet to convert it but im planing to by
Mikes Brushless Motor mount - Ofna CR Buggy, DM-1
Castle Mamba Monster Combos
not sure which combo will work better 2650 or 2200 you guys tell me
5s or 6s will need help choosing right batteris
Thanks Vitaliy
TexasSP 07.11.2011 09:57 AM
You will need to do a lot to hit 100 and it will take some time and experimentation. Due to the drag at high speeds the body will take a lot of work and customization to get right. I would even consider a gyro for the steering.
Personally I would look at the 2200 but maybe even go to a 1518 or 1520 sized motor and gear up. Possibly skip the MMM and get a phoenix so you can run 8-10s lipo and then use a mechanical brake as a motor brake coming down from 100 will really heat things up.
There are several people on here that have done setups like this and you will get plenty of advice I am sure.
Overdriven 07.11.2011 08:13 PM
The motor partly depends on availible gearing options and the amount of voltage you are going to run. If you're going to stay with 6s, and don't mind waiting for things too cool down between runs the 2650 or 2200 is good. If you have the gearing options or are going with more than 6s, the torquier 1518 or 1520 could suit your needs quite well. Either way 6s would be the minimum for cracking 100mph. One of my many winter projects will be a Losi 8ight running 8s on a 1518 or 1520 (have both and will try both) with the new MambaXL to make some speed runs. Should have a helluva lot of torque and pull any gear I throw at it.
As TexasSP mentioned aerodynamics will be an issue. A couple of things you have to do.
1. Make some sort of brackets to hold the sides of the body (bottom of the doors) so it doesn't flap around.
2.Fill or cover the hole in the windshield, same for the back window if there is one there too.
3. Cut the back portion of the wing off where the sticker "Protouring" is. At those speeds it'll make too much downforce, bottoming out the rear of the car and lifting the front which will make it blow over backwards. Leave the vertical sides in place for stability.
Those are the basics. I'm sure some of our resident guru's can chime in with other suggestions and how to implement them. Do some searching of the site, theres a bunch of info on what's been done to get where you are going. BTW, welcome to the forums!
rc hobby 07.12.2011 02:35 AM
Firs thanks guys for replys :)
for some reason im thinking 5s or 6s going to be less complicated than 8s +
what speeds i can reach lets say 6s and im thinking this combo Castle Creations Mamba Monster 2200kV V3 ESC ?
Did little work on it today took all nitro stuff off and ordered motor mount from mike and single speed adapter
http://i232.photobucket.com/albums/e...1/IMG_1619.jpg
http://i232.photobucket.com/albums/e...1/IMG_1617.jpg
rc hobby 07.12.2011 02:50 AM
what do you guys think about this battrys?
http://www.maxamps.com/Lipo-6500-222-Pack.htm
http://i232.photobucket.com/albums/e...50C_medium.jpg
http://www.rctoys.com/rc-toys-and-pa...BATTERIES.html
http://i232.photobucket.com/albums/e...0-6SPP45_1.jpg
PBO 07.12.2011 03:30 AM
I'm not overly familiar with the platform but 6S/2200 combo should get you to 100mph & a little beyond with some fine tuning
I'll say the MA packs are the least likely to get anyone's vote here :mdr:. The TP are probably OK but I'd seriously consider the Hyperion packs from Mike (RC Monster) there's some good pricing at the moment. Hyperion's are my favourite for high load scenarios. The Nano's from HK are also amazing for the price
You may also like to try the GRP MO1 rally tyres, they come in a belted version that is very durable & rock solid at high RPM. I'm assuming you're running OFNA's on the front in the pics
Post lots of pictures & video of your build
Overdriven 07.12.2011 10:24 AM
Like PBO said the 6s/2200 combo will get you there, just don't expect to make alot of back to back runs with no cool down time. But you could probably gear it for 50mph and play all day without worrying about temps. The beauty of a bigger motor with lower Kv is the greater torque and efficiency. The 8s/1520 combo I described in my last post could probably run around 75mph all day without overheating. But it's more costly and a little more complicated too.
As far as lipo's, there are better percorming packs than the Maxamps for the same or less money. My personal favorite is Hyperion also, and have used some Turnigy packs with great success as well. Check out the RC-Monster store for Hyperions that will outperform both those packs that you linked.
His fronts look like GRP, I think the rears are Ofna slicks which will never hold up. Get the GRP's and you'll have no worries about a tire blowing off the rim.
TexasSP 07.12.2011 11:13 AM
Do not get maxamps packs, they are guaranteed to fail. I cannot warn you away quick enough from them.
If you are serious about 100, I wouldn't waste your time on 6s and the 2200. Go right to the 1518 or 1520 and do 8s.
The 2200 will get you there, but on 6s geared high it starts overheating easily. That car weighs a fair amount and having a bigger motor will be a benefit.
Like Overdriven said, if you want to gear for around 50-60 on 6s with the 2200 you will probably be fine. It's just that the difference in power to go from 50 to 100 does not double, it compounds. Do some researching on aerodynamics and such and you will find how much resistance compounds going that fast.
bigbadtaz 07.12.2011 04:29 PM
try genaces packs i love these pack got hobbypartz.com
rc hobby 07.12.2011 07:55 PM
ok if i do go with 1520 and 8s what esc controler do i run with it link would be nice Thanks
What's_nitro? 07.12.2011 08:34 PM
FWIW, if this is your first BL vehicle I think a MMM/2200/6s combo geard for 50-60mph would be a good starting point to get you used to driving a BL car. Then after you've had enough fun with that you can modify it for more speed. :smile:
Overdriven 07.12.2011 09:35 PM
Yea, you'd be suprised how fast that is, and how quick a BL setup like the 6s/mmm/2200 combo can get it there! So I tend to agree, get the MMM/2200/6s and go from there. You may only throw the big pinion on a few times and get bored with going around 100mph. And you can always sell or put the MMM combo in something else.
But the easiest way to run 8s is with a controller like the Castle MambaXL
http://www.castlecreations.com/products/mamba_xl.html
Its a car controller, it has motor brakes, has a BEC, makes things simple. Only problem is its a bunch bigger than the MMM, and mounting 8s would generally mean 2 battery trays with 4s on each side, so theres that to figure out too.
The other option is air controllers like the Phoenix ICE HV line
http://www.castlecreations.com/produ...ix_ice_hv.html
These, like other air controllers, don't have a BEC (need an external one or a rx pack), doesn't have brakes (requiring mechanical brakes with a servo), and you need a Pistix adapter to use it with a typical pistol grip car controller. But you can run more voltage than the MambaXL
SV6000 07.13.2011 08:01 AM
Hi mate, converting a DM1 is hard. But here are some things that may help you. If you convert to single speed you will have to re-drill the center part of the chassis as the two speed is longer and if you are going to aim for 100mph is probably a better option especially with mechanical brake.
Before you go rushing into what packs and motor and speedy do some research and see how much room you actually have on the chassis. Are you going to run the motor on the right where the rx box is or are you going to put it at the left front so you can run two packs at the back of the car. the only reason i say that is the DM1 chassis is very narrow and does not allow itself well to have one large pack on the one side.
This is only what i found when i converted mine here is a pic.
http://i705.photobucket.com/albums/w...0/IMG_0182.jpg
rc hobby 07.13.2011 11:01 AM
Hi can you share your set up and what speed you getting with it
Arct1k 07.13.2011 12:18 PM
Search on JHautz - he did one of these a while back to.
