Castle Creations Baja Conversion kit 750kv vs 780kv
why have many online shops listed two separate kits, one 750kv thats a lot cheaper and a 780kv kit . whats the difference?
Links to examples?
So far as I know Castle only sell the 2028 motor in 780kv flavour.. |
it was actually on rcplanet, but when i looked now they have edited the listing
it was somthing like this: http://www3.towerhobbies.com/cgi-bin...&I=LXAWSH&P=OW http://www.ckrccrawlers.com/castle-c...nv-p-3233.html |
When we first released the info on the 2028, there was some confusion between marketing and engineering about the final kv of the motor. It was originally published as a 750kv but the final production versions were closer to 780kv.
Thomas Porfert Tech Support Castle Creations |
Thanks Thomas :smile:
Just wondering, do i have to gear the 5sc differently than the included 16t pinion? and is it safe to run it on 6s lipo(havent got an 8s pack yet)?
Also in the quick start guide states it is a switch somewhere, but i cant find it.
and the second wire with rx plug is powernig the fan? Sorry about all these silly question, i feel dumb |
The second wire is the fan. It's better to ask questions than break stuff:yes: |
thnx prob gonne route it to the reciver,
dont understand why castle have included such crappy screws the small one holding the tranny plate to the side uprights, have stripped 2-3 of them and cant get them unscrewed... the same with pinion screw it really sucks.. Never had any problem with screws before. it sems like its between 1,5mm and 2mm |
just finished, pretty satisfied. though i have some minor things left like solder connectors, mount receiver, paint, get an 8s ore two 4s battery, also thinking about cutting a hole in gear cover for the pinion as its slightly rubbing and maybe glue a plastic cup over so its sealed, may also shorten the gear cover screws and just bolt it right to plate and instead use tape to mount the cover.
still not sure how to remove those small stripped screws holding the tranny plate and esc, i may just cut the head off and remove the plate then remove the rest off the screw with a plier. also i had a hard time align the motor plate with the small chassie brace, as you can see in the picture its slightly warped.. everything aligned except that thing. still wondering about the 5sc\t gearing, it have bigger wheels(more speed with same gearing and rotation mass), body and so on.. and if i want to try it out with 6s will it still have enough power ore will i ruined the esc\motor? according to my bathroom weight its 14kg with 6s battery http://www.versland.net/5sce/1small.JPGhttp://www.versland.net/5sce/2small.JPGhttp://www.versland.net/5sce/3small.JPGhttp://www.versland.net/5sce/4small.JPGhttp://www.versland.net/5sce/5small.JPGhttp://www.versland.net/5sce/6small.JPGhttp://www.versland.net/5sce/7small.JPGhttp://www.versland.net/5sce/8small.JPG |
i have done a test run on 6s, not sure if im getting high ripple 2,08 at 23,5v almost 9%. Is this ok ore should i replace my 5,5mm bullets to 8mm! castles ones?
higest recorded current was 220 amp and 5000watt (not hard on the throttle at all) the motor was 47c (117f), i hope that 8s wont affect it to much. as it was only on tarmac. also i have a problem saving the log file, getting this error message: "Error while writing data to file Database error: translate language unknow (141), its english sting is not found." |
8mm bullets for 1/5 scale would be preferable, especially if you are pulling 220amp peaks. It could be that current draw & ripple comes down once you up the voltage, though it depends on how aggressive the gearing is currently & if you change it or not- not really so clued up on 1/5 scale issues myself..
im using the included 8mm bullets for the motor but on the battery side im using these: http://www.hobbyking.com/hobbyking/s...idProduct=2087
Just have a question, i have the rev 2 and im noticing especially with 8s thats it a bit notchy(not sure about the word).Like when i give it some throttle it hesitate for an split second for so to jump forward.
This isn't something that happens every time i give it throttle but frequently using 2 4s 5000 45c nanotech, the max ripple is 6% and futaba 3pm radio i have runned it 3 times, one time with 6s(9% ripple) and 2 times with 8s Hope for an answer thanks Fredrik edit, im on stock firmware |
| All times are GMT -4. The time now is 03:59 AM. |
