-   -   Downsizing the LST2 (https://www.rc-monster.com/forum/showthread.php?t=30324)
drkdgglr 07.28.2011 03:19 AM
Downsizing the LST2
As I have two E-LST's, a XXL and a LST2, I wanted to do something different with the LST2. I also had some other stuff lying around: A Mamba Max Pro, Leopard 3674-1790kv and a 5s lipo....
I decided to put the MMpro in the LST2 along with the motor and the battery. As these trucks weigh > 6kg rtr I needed to save some weight. So I put some Losi Truggy wheels on. The truck is now 5kg rtr (my LST XXL is 6.2kg with a MMM&1520).
The truck is geared conservitavely, 30mph (23/63). Yesterday I had my second run, with the body off, and these were the highest temps I measured:
Motor: 65c / 149f
MMPRo: 45c / 113f (fan never kicked in)
Ambient: 20c / 68f
MMPro settings:
punch: 25
timing: 0
start power: medium
firmware: 1.24
Looks like the MMpro is doing very well in the downsized LST2, but the motor temps should go down a bit.
If I switch to 6s and gear for 32mph (22/66) I can probably get the amps down, but how will the higher voltage and rpm affect the temps on the motor and controller?
http://i798.photobucket.com/albums/y...T/P1020126.jpg
http://i798.photobucket.com/albums/y...T/P1020125.jpg
suicideneil 07.28.2011 09:18 PM
Old rule of thumb:
hot motor + cool esc & batt = undergeared
cool motor + hot esc & batt = overgeared
hot everything = way overgeared
cool everything = just right
I think you should maybe try gearing up a little with 5s first before going to 6s- the truck may not be a lead-sled but the MMPro is generally best pegged at 4s lipo when used in an MT ( though with a ~2000kv motor too ). See how the temps react and take it from there..
drkdgglr 07.29.2011 02:42 AM
Thanks.
I didn't think about the old rules because I thought the motor just wasn't up to it. I'll try a larger pinion and see what happens.
