Turnigy new 300-400A 15s esc in baja 5b ?
Would this be a good esc for a baja5b conversion on 12s?
that esc is brand new and nobody has really used it yet, but based on everything i've seen/heard about it, it should be fine. you will need to use mechanical brakes most likely though.
all the esc from hk I used are burned and returned ....... trackstar, scanner, hk150a, sentilon etc etc ...... is your $ and your decission, but I think this esc will be the same :P ......
Hm sp there are no esc that can be used in a hpi baja yet ?
The castle one also goes up in flames :O) |
A warranty is only as good as the man who writes it - Thomas Callahan Jr.
I would call what they offer - customer dis-service - they just flatly do not care. You buy knowing if it dies, that's it, all over
Having said that though, they do sell sell some good stuff if you know (learn) what to buy That Fatboy is physically very large, would it even fit in a 1/5? |
| All times are GMT -4. The time now is 05:59 PM. |
