Best Backyard Bashing Motor
Ok here is a easy one. What is the best backyard bashing motor for my Stamped?I don't want to change the esc or any other stock parts if I don't have to. Thanks
"Best" is still determined by the weight of the truck, gearing, battery count, and desired speed...
I have a stock Stamped,I just need some Ideas. I'm running on grass&hills.
A 17-turn motor such as a Speedgems Extreme or Team Orion SV2 Pro or Reedy Flash Modified would all be good for a stock Stampede. Just make sure to lower your gearing. Since you run on grass and hills, I'd suggest a 14 tooth pinion.
Personal pick would be an Orion Method R 17x2 for about $20, very nice cheap motors.
| All times are GMT -4. The time now is 06:25 PM. |
