-   -   6s setup for 1/16 summit? (https://www.rc-monster.com/forum/showthread.php?t=30374)
speedy 08.13.2011 05:35 PM
What do you guy's think of this setupnfor a 1/16 summit?
Mm-pro + 6s + 1500ish kv motor geared for 45mph would that be an good
setup?how long runtimes could i get?
Fore lipo,s i was thinking of using a pair of 1000mah 3s 30-45c packs to save some weight compared to the 1500mah 3s pack that i run now wth thecstoch setup !
scarletboa 08.13.2011 09:23 PM
i like the idea a lot. the only problem is finding a good, 1300-1800kv motor (preferably 4 pole)
good luck with the build and pics, as always, are expected :angel:
speedy 08.14.2011 12:53 PM
How about a mega 16/25/motor they have 6poles ?
If i whant an outrunner that has equal or sligtlyĺ more tourque than a inrunner in stock motor size ! How big does the outrunner have to be?
E-Revonut 08.14.2011 02:52 PM
Good luck having the diffs hold up! The diffs are worse than the full size revos, I was blowing apart diffs on 2s after a few runs and on 3s I was lucky to have a diff last for more than an hour
Semi Pro 08.14.2011 10:53 PM
my diffs held up fine to the cm36 7700 on 3cell lipo and mikey84's diffs are holding up fine to the cm36 9000kv on 3cell so i think it really depends on the way you set up your diffs and how you drive it.
i
