Rampage TT5 vs XB: Which is tougher?
Hey all you 1/5 Rampage owners,
Which model has the stronger/more durable components and parts? The TT5 V4 or the new XB models? I am looking at which chassis to start with as foundation for a conversion (the way i want) and want one that will really hold up to abuse. Thanks. |
Well Ryan, the Rampaja i got from ya certainly holds up better than the Baja i have and puts the power down better. The truck is never the weak point, it is alway the non-mechanical bits that fail. I still run it without brakes and haven't broke it.
Although i havent used one of the XBs they just dont look beefy enough to me. The suspension arms and bumpers just look sorta thin to hold up to much punishment. As for the XB-E would ok i believe, if you could upgrade the electronics to atleast an 8s setup and go to a 1527 motor, but the xb-e has 100mm clearance for motor length and the 1527 is 101mm long. The stock xbe has roughly the same power output as my 8th scale buggy.
From what I've seen and read, the xbe does very well with a castle/neu 1717 or 1520, a MMM and and 6s. Even better with MMXL and 8s.
TG |
Im running an XB-E with the stock HW150a esc, CC1717, 7075RC motor mount w/48t spur and 10t pinion on just 6s. I am very pleased with the durability, speed and power of the setup. Sure, its not crazy backflip power, 90mph top speed or anything too extreme, it just works. The power is greater than any gasoline car I have ever ran, and I have had some seriously high dollar power plants mind you. At the Powerjam at LargescaleRC it was the fastest car there,nothing was even close. Unfortunately, I wasn't allowed to race with the gassers but I was allowed to run the qualifying heats with them. The announcer was begging anyone there to bring something to challenge it. I've had the car since Febuary, and running countless hours on the car, I have yet to break anything major. I stripped a wheel after I forgot to double check all the wheel nuts. I broke the wing on a BAD rollover in 35 degree weather. I toasted an ESC at Powerjam after they over watered the track in between heats. I broke a outer hinge pin after a bad landing at Powerjam. All the suspension, driveline and chassis components are still in A+ condition. I absolutely love this car, its been nothing short of amazing for me. |
Do you think the drive trane will hold up to a Castle 2028 and MambaXL on 8S. If I get an XB-E....that is what I will run....I will sell the Hobby Wing stuff. Thoughts?
Oh, and one more question...are the lipos that come with it of decent quality? |
The2028 won't fit in the XBE. No need for it anyway, as the car isn't nearly as heavy as the other 1/5 gassers out there. It's far more nimble though. The lipo packs that come with it are better off in some 1/10 scale car maybe. They aren't much use in the XBE, especially when you upgrade to a better motor. The ESC seems fine though. I'm running a CC1520 and haven't had any problems with the stock esc yet.
DISCLAIMER: I am totally high on painkillers from having a busted up knee. That coupled with the fact that I just woke up from a 4 hour nap may make my posts rather reatrded sounding. You have been warned :D
Killa is right the 2028 will not fit, its too long and too fat (thats what she said right?) About the largest diameter motor that will fit into the stock XB-E is the CC1717. So basically about 48mm diameter and 100mm in length is about all you can squeeze into the stock setup. There is a guy that makes aftermarket accessories for the XB-E, he has a motor mount that will allow the 5692 to be dropped it. It is a bit pricey, but so far mine is holding up fine with the delrin Spur. I have some video of the XB-E with CC1717, stock batteries (which could handle the amp load just fine but were too low MAH to get a decent runtime) on 6s and the stock ESC. Shot on my phone so the quality isn't the greatest. I was doing to recording and driving, so my driving or the action wasn't the best. http://www.youtube.com/watch?v=jrjvTt-eHrE <iframe width="480" height="390" src="http://www.youtube.com/embed/jrjvTt-eHrE" frameborder="0" allowfullscreen></iframe> |
Edit: he is the only person I've seen selling rollers of the XB-E though, and that part is tempting |
If you want rollers, PM me. I will do my best to get one.
Seeing as this (links below) just came out i think i am going to go this route. Its losi, so it will be tuff, and there will be huge parts availability and after market hop-ups too. The only bad thing is that is a RTR and i would prefer a kit as i dont need the servos, gas motor, or radio. I am guessing they might release a kit form in 6 months or so. They do already have hop-up parts available. And the chassis layout will be super easy for a nice conversion. Looks like it could fit a Castle 2028 motor no problem. The dimensions look real nice.
http://www.youtube.com/watch?v=JN7XUFlS5PI http://www.largescalerc.com/losb0019...d-n-drive.aspx ENJOY!!!!! |
| All times are GMT -4. The time now is 06:01 PM. |
