-   -   Mm settings for outrunners ? (https://www.rc-monster.com/forum/showthread.php?t=30412)
speedy 08.23.2011 03:51 PM
Hi !
What settings chould i use if i whant to run a outrunner motor with a mm esc ? I've tried to run it but it hesitates a litle bit on startup now!
I have the timing st to lowest now , chould i advance it to normal or even high setting?
What's_nitro? 08.23.2011 04:07 PM
Outrunners typically work better with higher timing. Try "normal" first. Also, depending on the vehicle/battery, start power can be raised also.
Pdelcast 08.23.2011 05:54 PM
Because the CC controllers advance timing based on motor inductance, we usually recommend "low" timing for outrunners. So a little different than most sensorless controllers...
Thanx!
sikeston34m 08.23.2011 06:05 PM
Yes, but he said a MM Esc.
Which MM is it though? I know the older versions of the MM didn't do so well with outrunners.
If it is an older MM, update the firmware and you will see a world of difference. :yes:
slimthelineman 08.23.2011 07:14 PM
I ran an outrunner for a while in a 4x4 slash with a mmpro and got it to work best with 0-5 degrees of timing and med-high start power. Was using tp 3s 3200 40c packs. Really flew and ran super cool but the brakes weren't as strong as I like when using the outrunner motor. Would ease into raising the start power though and keep an eye on temps and use some nice packs. Tried the same motor on 2s and it did not work well.
speedy 08.24.2011 03:51 AM
i have an older mm esc with the 1.19 firmware i think ! i tried the new firmware but then the esc stopt responding to throttle input and the lights were blinking ? so i whent back to the old firmware.
